Dzisiaj jest 27 paź 2026, 18:23
Post: 31 paź 2012, 7:58
This makes swarovski steine a perfect accompaniment to any type of finding as the beads catch the light and really do sparkle with an iridescent shimmer. They are particularly popular used as charms and are incredibly easy to incorporate into even the most simple of designs.To make your own charms using Swarovski crystal beads, you only need the most basic of jewellery making equipment. And you don't necessarily have to use them to make jewellery either they can also be used to add a special sparkle to clothes or even mobile phone covers. All you need to make simple charms are a pair of round nose pliers, flush cutting pliers, a selection of crystal beads and perhaps some accent beads to add a flourish to the design, silver or gold jump rings and silver or gold eye or head pins. Decide on the design you'd like to create using a combination of Swarovski crystals and accent beads. String the beads onto a silver or gold head or eye pin, depending on your design. Leave enough length at the end of the pin so that you can make a loop for hanging and use the flush cutters to trim any excess wire from the end of the pin.
Use the round nose pliers to bend the remaining wire into a loop to finish off the charm. The smoother the loop, the better and stronger the charm will be. If you're able to solder skilfully you can give a more professional finish by soldering the join in the loop to secure your charm properly. Once you have several charms you can then string them together to make a cluster effect necklace or sew them onto a jumper or cardigan to give it a new lease of life and added sparkle.swarovski ohrringe are incredibly easy to use and look stunning for very little cost.Good suppliers of crystals will carry a wide selection of colours and effects and the crystals have become so popular that there are even artists creating large sculptures incorporating the iridescence and shimmer of these simple but beautiful beads into their work. They are particularly good for children jewellery projects as the bright colours and tactile nature of the crystals appeals to younger jewellery enthusiasts. The best way to discover the nature of these crystal beads is to buy a bag and just sit down and create your own designs with them. The only thing that limits you is your own imagination, so let it run wild and see what happens!.
http://www.swarovskischmuckohrringe.de/
swarovski schmuck
swarovski steine
