Dzisiaj jest 04 lip 2026, 0:48
Post: 18 wrz 2010, 22:31
----- Initializing Renderer ----
execing ragdoll.cfg from disk
----- Client Initialization -----
----- Client Initialization Complete -----
Trying SMP acceleration...
...succeeded.
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Shader model 2.0 code path is available.
Shader model 3.0 code path is available.
Using Shader model 3.0 code path because it is the best available path on this hardware.
Attempting 1024 x 768 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Loading fastfile code_post_gfx
Loading fastfile ui
Loading fastfile common
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Loading fastfile 'code_post_gfx'
used 1.13 MB memory in DB alloc
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Setting initial state...
Loading fastfile 'ui'
used 39.48 MB memory in DB alloc
DirectX reports 128 MB of video memory and 1219 MB of available texture memory.
Using video memory size to cap used texture memory at 112 MB.
Texture detail is set automatically.
Using picmip 1 on most textures, 1 on normal maps, and 1 on specular maps
Error: Could not load material "water_droplet".
Error: Could not load material "water_dynamic_spray".
------- sound system initialization -------
Error during initialization:
Unhandled exception caught
Może ktoś wie co jest nie tak???
Pozdrawiam :)
Post: 19 wrz 2010, 9:33
Może karta graficzna jest za słaba. Zainstaluj najnowsze sterowniki do karty graficznej i wtedy spróbuj a jak nie pomoże to wymień karte. Podaj jaki masz sprzęt to będzie łatwiej
i co to za gra
Wejdź i oceń mojego speeda
Ostatnio zmieniony 19 wrz 2010, 9:35 przez Blackout, łącznie zmieniany 1 raz
Post: 19 wrz 2010, 9:49
Co to za gra ?
My Aprilia SR'R :
http://forum.mieloch.pl/viewtopic.php?t ... d469b6be03
Komentować :P
Post: 19 wrz 2010, 10:01
Jest to gra Call of duty 5
Pozdrawiam :)
Ostatnio zmieniony 19 wrz 2010, 10:03 przez piotrex, łącznie zmieniany 1 raz
Post: 19 wrz 2010, 17:38
wiem ze grafika to 256 mb ale kiedyś ta gierka chodziła a teraz nie.
Pozdrawiam :)
Post: 19 wrz 2010, 17:51
Poszukaj na pudełku, może jest napisany gdzieś numer telefonu do pomocy technicznej :D :D :D
Przeinstaluj directx, sterowniki do grafiki i do audio najnowsze?
bikepics.com
Post: 19 wrz 2010, 18:40
takie sterowniki do audio i grafiki znajdę w necie?
Pozdrawiam :)
Post: 19 wrz 2010, 21:01
sterowniki znajdziesz na stronie producenta karty graficznej albo wpisz w google stery do karty jakiejś tam i zainstaluj
Post: 24 wrz 2010, 21:46
Coś tam pisało o Vertexie to może tłoka wymień :):)
zainstaluj sterowniki i może directx i powinno śmigać a może jeszcze gre przeinstaluj
Sprzedam wszyskie części do NRG P/G !!!!
"nie bądź taki prędki, uważaj na dętki :lol:"
Post: 25 wrz 2010, 10:03
Pojazd: CBR 600 F3
wg mnie brakuje jakichś plików gry możliwe bad sectory na płycie
spróbuj wywalić grę wyczyścić rejestr i spróbować od nowa a jak nie da rady to z inną kopią spróbuj
